Hello everyone, this is my first post here. I am looking to start a new project with a Graphic LCD display. I want to use a serial connection to free up pins on my PIC and possibly remotely mount the GLCD, and running 3-4 line can be done with a phone cord. My problem is cost for a serial module. So i thought i might try to make my own. So i looked on ebay for a display and i found one that is pretty cheap..$ 14.00 Blue BL/Whit letters.
So i looked at the data sheet here:
http://www.pic16.com/soft/12864_jhd529.pdf
Pin 15 is for SERIAL/PARALLEL SELECTION ... So if i am right, i can select serial and i dont need D0-D7 pins connected to my PIC, they are 8-bit parallel line. I can use a serial connection or I2C. This would greatly lower the number of pins need from my PIC to run the GLCD....also i am using Proton PICBasic.
So my question is how to interface the GLCD with serial signal form my PIC? How do i connect the pic to the GLCD??
Thank You!!
Thank You!!
