Help with a couple, tricky Series-Parallel Circuits
Discussion in 'Homework Help' started by Maroon113, Oct 30, 2014.
  1. Maroon113
    Oct 10, 2014
    Hello all, this is my first time posting on here. I have run into a couple problems in a DC Electronics class, that keep beating me up. They are attached to this post. They are pretty deceptive IMHO, and I have spent hours trying to conquer them. To no avail...
    #1:
    #2:
  2. WBahn
    Mar 31, 2012
    18,093
    4,920
    I agree that Part (b) on the second one is real tricky, since the directions of I1 and I2 are undefined.
    Since you have spent hours trying to solve these, you should be able to post your best attempt for us to use as a starting point. It is, after all, YOUR homework.
    Hint: The two voltages (V1 and V2) in the first problem and two of the voltages (V1 and Vb) in the second problem can be written down by inspection, provided you understand what voltage is.
  3. studiot
    Nov 9, 2007
    5,005
    515
    These are not elementary arrangements, but there are several solution methods available.
    You must have studied some further methods than series/parallel combinations to have been set these.
    So let us start by you telling us which ones and showing us what you have achieved so far.
