hello.
for a schoolproject I am using a capacitorbank. however, I have some troubles charging it. it cointains out of 8 350 volt, 1000 uF capacitors. unfortunately, our school can't provide me with a 350 volt powersupply. they do however have some other powersupplies which go up to 30 volts. I also want to have some kind of indicator which tells me when the capacitors are fully charged.
Off course it is possible to take the charger circuit out of a disposable camera, but I could not get one of those. I also figuered it would most likely not survive decharging the capacitors.
so my question is, can you help me with my circuite, if this is at all possible.
