Help With A.c. Schematic
Discussion in 'General Electronics Chat' started by ronmuf, Oct 22, 2007.
  1. ronmuf
    Oct 22, 2007
    Please help !!
    I have a schematic for Single Phase 220 v A.C. Wiring for a lathe.
    The schematic shows connections to the Electrical Distribution Panel labeled U1, V2 and Z1.
    Can anyone please help translate?
    Which one is the Neutral?
    Thanks so much !!!!
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Do you have access to an ohm-meter?
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    If you have the meter, check to see if you get equal resistance from one lead to the two others - that should be the ground.
    Lacking that, open up the accrees to the motor and trace the leads to the motor. The plate that covers the wiring connections should have a diagram on it that will show what is what.
  4. GS3
    Sep 21, 2007
    408
    35
    Are you sure it is single phase? The nomenclature suggests otherwise. At any rate this PDF document might help.
