Hi can someone help me to understand this code. I found it in Proteus file :
VSM for 8051
8051 Stepper Motor Controller
Also can you explain the operation of ULN2003A?
TQ.
VSM for 8051
Rich (BB code):
FILE NAME: stepper.c
CHIP TYPE: AT89C51
CLOCK FREQUENCY: 12MHZ
IDE: VSMStudio
COMPILER: IAR for 8051
TIME: September 2010
#include "ioAT89C51.h"
// Definition for output port and input pins
#define out_port (P2)
#define key_for (P0_bit.P0_0)
#define key_rev (P0_bit.P0_1)
// Define new types
typedef unsigned char uchar;
typedef unsigned int uint;
void delayms(uint);
// Array of Stepping Sequences
uchar const sequence[8] = {0x02,0x06,0x04,0x0c,0x08,0x09,0x01,0x03};
void main(void)
{ uchar i;
out_port = 0x03;
while(1)
{ // Has the forward key been pressed ?
if (!key_for)
{ i = i<8 ? i+1 : 0;
out_port = sequence;
delayms(50);
// Has the reverse key been pressed ?
else if (!key_rev)
{ i = i>0 ? i-1 : 7;
delayms(50);
void delayms(uint j)
{ uchar i;
for(; j>0; j--)
{ i = 120;
while (i--);
TQ.
