Hey guys,
I'm kind of stuck on this homework problem in my Logic Design class and I was wondering if anyone could give a few tips on how to start the solution process. Thanks
A eight bit adder AM8 has a carry input C0 and inputs A7A6A5A4A3A2A1A0 and
B7B6B5B4B3B2B1B0 and sum output S7S6S5S4S3S2S1S0 and a carry output C8.
(a) For unsigned addition give the range of values that can be represented by the inputs.
(b) You have a block AM4 that takes two 4-bit numbers X3X2X1X0 and Y3Y2Y1Y0 and carry input Cin and gives a 4-bit sum output Z3Z2Z1Z0 and carry out Cout. Build the eight bit adder using only AM4 modules. Show all connections and label all inputs and outputs of AM4 and AM8.
