i am trying to make ua741 op amp works as non inverting amp
i have connected the very basic circuit consisting of two resistor Rf and Rin
and the gain now should be 1+(Rf/Rin) but the problem is that gain is always one
i have connected it in inverting and tried different values for the resistor but it still not working
Well, honestly i think i burnt the amp by directly connecting +Vcc to 12 v 600mA source and -Vcc to gnd
and i later calculated that i would need 288 ohm resistor to be connected (not sure from that)
i calculated by looking at the datasheet the maximum power for that amp were 500mW and my input is 12 v
so the max current is 41,66mA and the resistor would be 288 ohm.
now before trying to connect a new amp, i am trying to realize what could went wrong
from my power supply what circuitry should be connected before the amp
do i need +12 and - 12 even though i am just trying to amplify a positive signal all the time (out put from Wheatstone bridge)
what wrong with the following simulation circuit, why its not working
Thanks A lot
Thanks A lot
