Help with 5v 167mah solar panel and phone charging
Discussion in 'General Electronics Chat' started by Biospaz, Aug 2, 2014.
  1. Biospaz
    Aug 2, 2014
    Hi, I've been looking online to try and understand how to build a solar panel cell phone charger and all the projects I've found either center around just connecting straight to the 6v 167mah solar panel found at radio shack or praying a USB charging control panel from a backup battery for the purpose of converting the power. In only one design did I see someone use a couple diodes to refuse and clean the power to 5v Nessesay for a USB. However, I don't understand how this would address the glaring current issue. As I understand, most phones require at least 1ah to properly charge. Is there a way to properly address the above issue with a transformer and/or combination of capacitors/transistors to get the desired current from just one panel or would I need more panels in parallel to achieve this desired result. Or, am I just completely misunderstanding the projects I saw online and am over thinking the situation. I am very new to this and I am trying to this project as a mental exercise to learn more. Thank you for any help you can provide in helping me learn this super complicated world.
  2. AlphaDesign888
    Jul 27, 2014
    189
    10
    I think you are doing your head in a bit. You're all over the place with what you are saying.
  3. wayneh
    Sep 9, 2010
    12,398
    3,246
    You need more panels. Most phones will require far more than 100mA to charge up in any reasonable amount of time, and many will not even initiate charging unless they can see a good supply of current. A full 1A may not be necessary, though.
    There are DC-DC converters that can adjust voltage levels for you, but nothing can change the fact that there is not enough energy coming in from the panel.
  4. MrChips
    Oct 2, 2009
    12,648
    3,459
    If I wanted to charge my cell phone from a solar panel (but I don't because I don't own a cell phone) here's what I would do.
    I would get two 6V sealed lead acid batteries. While one is being charged by solar power the other is being used to charge the phone. I would put a 5V regulator connected to a USB jack to charge the phone.
  5. AlphaDesign888
    Jul 27, 2014
    189
    10
    Seems like good advice to me.
    You don't like smart phones? This site is quirky with an 3.5" touch screen.
    I don't even have spell check :eek:
  6. wmodavis
    Oct 23, 2010
    737
    150
    Solar panels not spec'd with mAh - That's for batteries.
