help with 555 timer
Discussion in 'The Projects Forum' started by starrz, Jan 6, 2013.
  1. starrz
    Jan 6, 2013
    17
    good day everyone, I am trying to build a circuit that can turn a relay on , off, then on again maybe in a 2 seconds interval and remain in that state until powered off and repeats this same cycle every time its powered on. I am familiar with 555 timer ic and 4017 ic which was the initial circuit i was trying to modify to achieve this effect however it cycles continuously where just one cycle is desired. It also doesnt have the power output to drive a 12v relay. Could anyone guide me in the correct direction , your help will be greatly appreciated
  2. tracecom
    Apr 16, 2010
    3,879
    1,396
    I can see how it can be done with three 555s, but there may be a simpler way, and someone will disclose it.
  3. starrz
    Jan 6, 2013
    17
    any suggestions would be greatly appreciated, i also have some 556s if you all think it can be utilized
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    I've actually designed this. Got to go to work, but you can browse my blog for ideas until I have more time.
    Bill's Blog
    Metalmann likes this.
  5. starrz
    Jan 6, 2013
    17
    my there is a lot of blogs on page , is there a name for this type of circuit and could you narrow give me a little more insight on what i should try and search for thanks
  6. tracecom
    Apr 16, 2010
    3,879
    1,396
    Is this the sequence you want?
    Initial condition: Power is off and relay is not operated.
    1. Power is turned on by external force.
    2. Relay operates.
    3. Pause 2 seconds.
    4. Relay releases.
    5. Pause 2 seconds.
    6. Relay operates.
    7. Pause until power is turned off.
    8. Power is turned off by external force.
    9. Relay releases.
    Back to initial condition.
    It can be done easily with a microcontroller. Are you interested in that or do you prefer an analog solution?
  7. starrz
    Jan 6, 2013
    17
    its exactly what am looking for, all longs as parts can easily be sourced am up for the microcontroller, please elaborate i have been struggling with this for a while using 555s
  8. tracecom
    Apr 16, 2010
    3,879
    1,396
    Here is a link to a kit which contains everything you will need for the circuit except the microcontroller and the relay.
    http://www.picaxe.com/docs/axe021.pdf
    Here is a US source for the kit and the microcontroller (08-M2).
    http://www.phanderson.com/picaxe/picaxe_rev_ed.html
    Here is a link for more information and the free software to program the microcontroller.
    You will also need a programming cable, either USB (which is about $22) or serial (if you have a serial port on your computer) and is much cheaper and can be home built.
    There is a learning curve, but it's not steep. Have a look at the links and see what you think.
  9. starrz
    Jan 6, 2013
    17
    great suggestion but may i ask what would the analog solution look like, sourcing of parts is a main factor her being whatever my local shop can provide, my best bet is that they most likely have the parts for the analog approach available.
  10. tracecom
    Apr 16, 2010
    3,879
    1,396
    Where is "here," i.e., where are you?
  11. starrz
    Jan 6, 2013
    17
    trinidad to exact, we have radio shack but they cant come near what radioshack offers in the U.S. They dont have any of the popular parts available and other local spare parts shop stock alot more but focus mainly on parts needed for appliance repairs with a few 555s and 4017s just as a bonus
  12. tracecom
    Apr 16, 2010
    3,879
    1,396
    Here's what I think will work. It's not very elegant, but it makes use of the parts you have, plus a few.
    Build a 555 astable with a 1 second on/1 second off output. Connect that to the clock input on the 4017. Connect a non-inverting relay driver circuit to the number 0 output on the 4017. Connect a transistor latch circuit (which will also serve as a non-inverting driver circuit) to the number 2 output. Use two diodes to OR the two driver outputs together, and connect the OR output to the relay (using a protection diode across the coil.)
    A non-inverting transistor latch circuit is attached. You can use an identical circuit, but without R3, for the non-inverting relay driver.
  13. starrz
    Jan 6, 2013
    17
    so with this latching circuit its gonna run on , off, then on and latch right there?
  14. tracecom
    Apr 16, 2010
    3,879
    1,396
    My thinking is that when power is applied, the 555 willl start clocking the 4017. When output 0 of the 4017 goes high, the relay will operate for 2 seconds; then the 555 will go low/high, the 4017 output 0 will go low, output 1 will go high, and the relay will release for 2 seconds. The third time the 555 output goes high, the 4017 output 2 will go high, and the connected transistor circuit will go high and latch. During this time, the 555 and the 4017 will continue to run, but they have no effect because the transistor latch is latched and holding the relay operated. Only when power is cut does the entire circuit power down and the relay releases. Then, the cycle is ready to start again.
  15. tracecom
    Apr 16, 2010
    3,879
    1,396
    I have done some experimenting with the 4017, and, while I still think my previous suggestion will work, there may be an easier way. I'll post more when I know more.
    How will power be turned on and off?
  16. ScottWang
    Aug 23, 2012
    4,934
    777
    If the condition as tracecom listed, then maybe you can use NE555 and CD4017 and some 1N4148 diodes Bjt circuit and relay to do the Job.
    NE555 2 Seconds → CD4017 → 1N4148 → R → NPN Bjt → Relay
  17. starrz
    Jan 6, 2013
    17
    another 12v circuit with a IR remote is feeding this one
  18. tracecom
    Apr 16, 2010
    3,879
    1,396
    I am watching the BCS game, but I will post a simplified solution later tonight or tomorrow.
  19. tracecom
    Apr 16, 2010
    3,879
    1,396
    I want to recheck this, but it should be close. Maybe ScottWang or somebody could verify it?
  20. starrz
    Jan 6, 2013
    17
    i actually have the 555 and 4017 connected in a breadboard using a 9v battery just for testing purposes at the moment. whenever i connect that output 2 to clock disable output 0 just remains on and is stuck right there no other leds light up. i actually have alot of 3904s in hand
