Help with 5 bit weight computations
Discussion in 'Homework Help' started by Robbinz, Nov 11, 2011.
  1. Robbinz
    Nov 11, 2011
    First post :)
    I am fairly rubbish at Electronics. My preference is power engineering. However I have a coursework to do for digital electronics. My understanding of digital is pretty lame.
    Im not looking for answers to the question, I just need help understanding it lol.
    Can anyone please point me in the right direction with this? The question is:
    "Your task is it to design and test a digital circuit to compute the weight of
    a 8-bit input vector. Furthermore, the circuit has to be able to detect the
    lowest weight vector, assuming that the 5 input bits cannot all be 0 or 1.
    Design and test can either be performed using MatLab or Tina. Beneath the
    implementation using logic gates also explain and give the implementation​
    using either ROM, PLA or PAL devices"
    Any help would be MUCH appretiated
    thanks
  2. thatoneguy
    Feb 19, 2009
    6,357
    718
    A binary to decimal converter?
    In the context, "Weight" usually means how close to the most significant bit a bit is, but am unclear on if they want you to find what the highest weighted position with a set bit is, or if they want the input converted to decimal.
    Example:
    0b01000011 -> Weight is 6 (bit number 6), or 64 decimal, since bit 7 isn't set, the LSB 11 don't add in. Bits are numbered 0 to 7 starting from the right.
    or
    0b01000011 -> is 0x43 hex, or 67 in decimal for straight conversion
    If you have had similar questions/lectures where the answers were shown I might understand the context of what they are looking for a bit better. I have no idea where the 5 bit comparison is in the question, though that is the title of the thread...
  3. Robbinz
    Nov 11, 2011
    This is exactly the problem. I dont really understand the question :/
    And the lecturer really does not help.
    I think it means weighting as in how many 1's are included.
    Like 1011 has a weighting of 3 or 011 in binary and 0011 has a weighting of 2 or 010.
    The only related thing we have done in tutorials is the quine mccluskey method. Ive tried this and got down to an output of f = AB'C' + A'C + A'B
    But now im trying to put it into a pal form circuit and have no idea if its correct :S
  4. thatoneguy
    Feb 19, 2009
    6,357
    718
    What is the 5 bit part mentioned in the title?
