help with 24VAC current sensing with shunt resistor
Discussion in 'General Electronics Chat' started by JasuFIN, Aug 30, 2016.
  1. JasuFIN
    Aug 30, 2016
    I read few threads about this same problem, which almost everyone was guided to another direction because the high AC mains voltage violates the terms of services. For example: http://forum.allaboutcircuits.com/threads/ac-current-sensing.76878/
    I am trying to design a current sensing circuit, based on shunt resistor, for measuring synchromotors current (170mA @ 24VAC)
    I tried (before properly inspecting the datasheet) LTC1966 true-RMS converter, which in my opinion, would have worked if the AC voltage was in the limits of rail-to-rail voltage applied to the IC. However the common-rail voltage is obviously out the limits for the LTC1966 (0-3,3V in my case).
    There is various options for AC current sensing which I'm aware of but none of those seems to suit for measuring such a low current.
    The current measurement, in this case, doesn't need to very accurate. The current only determinate whether the motor is functioning properly or not. The current is measured from 8 different motors with ATXmega128's ADC.
    Would it make any sense to try to overcome the common-rail voltages with AC-coupled instrumentation amplifiers?
    Please see the attached pictures of the "theory of operation" and the unsuccessful test with the LTC1966
  2. JasuFIN
    Aug 30, 2016
    Solved
