help with 220 volt DC motor
Discussion in 'General Electronics Chat' started by mohamed Sami, Oct 20, 2015.
  1. mohamed Sami
    Aug 15, 2015
    16
    I have a universal motor 220V 1.5A and want to control its speed.
    I made bridge to convert 220V AC to DC and transformer with bridge to get 24V DC.
    I connected it like this image as R3 is the motor and R2,R1 is potentiometer. I used mosfet IRF644.
    Screenshot from 2015-10-20 05:45:30.png
    But the motor works with full speed whenever the potentiometer is even if potentiometer is not connected.
    So how to solve it ?!
  2. Dodgydave
    Jun 22, 2012
    5,130
    766
    You need to connect both negative sides of the power supply together, problem is as soon as the fet gets enough gate bias it will turn hard on, better to use PWM control for smoother action.
  3. mohamed Sami
    Aug 15, 2015
    16
    no change happened the same
  4. TheButtonThief
    Feb 26, 2011
    219
    38
    Where is your motor in the circuit?
    Are you representing it with R3?
    mohamed Sami likes this.
  5. pwdixon
    Member
    Oct 11, 2012
    488
    56
    That FET only has a 20Vmax Vds spec, and the gate voltage limits are +/-5V so you've exceeded that too I'm afraid, it's probably dead by now. OK withdraw all of that now I see you mention a different FET in the text, I was using the one on the schematic.
    But then if you used a bridge from 220Vac to dc then you will get a peak of 220*1.4=308V which exceeds even the IRF644.
  6. pwdixon
    Member
    Oct 11, 2012
    488
    56
    By the way there used to be board rules against posts with rectified mains as it was very dangerous but perhaps they were relaxed in the board rule changes.
    recklessrog likes this.
  7. recklessrog
    Member
    May 23, 2013
    346
    102
    The danger still remains though!
  8. Alec_t
    Sep 17, 2013
    5,952
    1,129
    If the motor is indeed a universal motor it would be a lot simpler to power it with AC and use phase-control (i.e. as in a conventional light-dimmer) to vary the speed.
    mohamed Sami and MaxHeadRoom like this.
  9. strantor
    Oct 3, 2010
    4,302
    1,989
    either your FET has failed shorted, or you've connected it backwards.
  10. ScottWang
    Aug 23, 2012
    4,924
    776
    You can change the VR1 and C1 to change the frequency for PWM.
    If you don't like to use zener then you also can use 78L12 to be the voltage regulator.
    The mosfet you can choose at least 2 times rating of Vds and 3 time of Id, of course great than more is more better.
    2SK2843_Nch_600V10A_540mΩ_Dc2Dc_Motor_Toshiba.pdf
    FQA19N60_Nch_600V18.5A380mΩ.pdf
    IRFS9N60A-Nch_600V9.2A_0.75Ω.pdf
    NTE2995_Nch_600V10A_±30V_Vgs10V_650mΩ.pdf
    STW-88N65M5_Nch_650V84A-24mΩ.pdf
    Bordodynov likes this.
  11. MaxHeadRoom
    Jul 18, 2013
    10,818
    2,494
    I concur with @Alec_t, Why not use the common way of a Triac on AC?
    In any case you are not going to get accurate speed control without feedback of some kind.
    Max.
  12. ScottWang
    Aug 23, 2012
    4,924
    776
    Max :
    Using triac on AC for motor will make noise, I was used that for fan, unless change the frequency, if don't care about the noise that it can be used for that.
  13. mohamed Sami
    Aug 15, 2015
    16
    yes
  14. mohamed Sami
    Aug 15, 2015
    16
    i used the one in text IRF644. ok how to get 220 DC ?
  15. mohamed Sami
    Aug 15, 2015
    16
    it is universal motor but how to control its speed using arduino ?
  16. MaxHeadRoom
    Jul 18, 2013
    10,818
    2,494
    See Fairchild AN-3006.
    Complete with necessary isolation.
    Max.
  17. mohamed Sami
    Aug 15, 2015
    16
    @ScottWang @MaxHeadRoom i will use feedback for sure but how to control speed of universal motor using triac ?
  18. MaxHeadRoom
    Jul 18, 2013
    10,818
    2,494
    What type of feedback do you intend?
    Max.
  19. mohamed Sami
    Aug 15, 2015
    16
  20. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    Did you check if the MOSFET has failed short circuit? - I'm thinking you'd need at least an IRF8xx to handle the voltage - with all that sparking at the brushes and inductive back emf, even that probably isn't enough.
    Ignoring back emf and any mains transients, the peak value is somewhere near 320V - your MOSFET has to handle at least that, plus a good safety margin.
    Start with a MOSFET that can actually handle the voltage, and protect it from spikes, back emf etc with a MOV.
