R!f@@
Hope you get the project done in time - I don't want to be responsible for you missing the deadline!! Do you really live on the Maldives too!!??
The photos are of one of the dead boards. The Intel Atom dual core chip is soldered unforunately.
My first install had the components mounted on a simple wooden board. This was fine (for 6 months+) until I drove over a small pothole in the road and the PC just stopped - suggested something perhaps shorted??
For the replacement board, I thought it would be better in a proper mini ITX enclosure. I was testing the PC in the car and everything booted up and then again suddenly stopped with the same apparent damage. I seem to remember the ITX case tapped against the plastic dash just as it all went off.
No smell of burning, no smoke.
Yesterday I decided to remove some of the components I had attached to the board which were still in the car. The only thing worth noting was the USB FM tuner. I had soldered a car aerial adapter onto this and noticed that one of the aerial signal wires had become detached. There was noticeable verdigris on the other wire. The car aerial is powered/amplified...
I plugged the FM radio tuner into my home PC to test and it is still working.
Other components plugged into the motherboard included a PCI wireless NIC (working), the USB signal from the touchscreen monitor (monitor working fine), GPS receiver with serial and PS/2 connector (not tested), audio jacks to amplifier (front and rear), VGA to monitor, 2.5" SATA HDD. One 2Gb DDR2 memory.
In addition to the SATA HDD and ATX + 4pin P4 to the motherboard, the PSU was also running 2 x cold cathode fluorescent tubes.
That's all I can think of!
In addition to the regulator/transistor getting hot, the southbridge does get slightly warm even with no other signs of life from the mobos, other than the green "ATX power connected" LED near the RAM slot.
I'm not sure if it is possible, but would expect any problem to have come through a USB slot. Otherwise, it has to be the PSU!!?
Thanks,
David
Thanks,
David
