help with 1st LED setup
lfcreds91
Joined May 4, 2011
5
i will be setting up my 1st LED base.....
this is how it looks.
the LED will be a 5mm spectrum or rainbow LED.......those that changes color every 0.5 sec.
battery will be 27 V, by joining 3 9V battery together.
resistor will be a 1/4 470 resistor.
the problem is i dont really know the LED forward voltage/current.
judging by the above setup, do you guys think its good to go?
or is it gonna BLOW!!!!!!!!!
Wendy
Joined Mar 24, 2008
23,421
Care to show us the rainbow LEDs datasheet or source? They are circuits unto themselves you know, so the normal rules on LEDs do not apply.
Wendy
Joined Mar 24, 2008
23,421
They mention 3V. 4X3V is 12V, so you have 27V-12V (15V).
15V/470Ω is 32ma, which is good enough.
However, your resistors will dissipate ½W. A general rule in electronics is over rate components by X2, so you would need a 1W resistor.
Instead, how about putting the 4 LEDs in series for 8 LEDs. This would create a 24V drop. Then put a 100Ω resistor in series with them. That resistor would dissipate 90mw, much cooler.
lfcreds91
Joined May 4, 2011
5
sorry , but im not understanding your suggestion.
is this what you are suggesting?
so, my setup with 27V, 470 ohm is good to go right?
bertus
Joined Apr 5, 2008
22,277
I do not know if the current will change when the colors are changing.
If that is the case the pattern will show changes in current
wich also will change the voltage on the leds,
due to then fised resistor.
Bertus
Wendy
Joined Mar 24, 2008
23,421
or is this what you meant?
This was what I was talking about. Since these are not regular LEDs (like I said, actually circuits on chips) there is a bit of chance involved here. I've never messed with them myself.
Odds are they will be out of sync with each other, each LED doing its own thing.
KJ6EAD
Joined Apr 30, 2011
1,581
These circuits want a constant voltage so just find a way to wire them in parallel with 3-4.5V each. 2-3 D cells should just about do it. By connecting them in series, you risk destroying them since the voltage drop of each is not constant, not even close. If you don't believe me, just hook one up to 3V and measure the current as it operates.
The 3V rating is probably a minimum. The ones I've used all wanted 4V. When you consider that the blue LED in the device needs ≈3.8V to draw it's full current, the higher supply voltage makes sense. Consider this datasheet for example: http://www.etgtech.com/pdf/oldspecs/RAINBOWLED.pdf. Try to get some real specifications from the seller. When you have the right supply voltage, the device should draw a peak of ≈65mA.
Audioguru
Joined Dec 20, 2007
11,248
I agree that color-changing LEDs should never be connected in series.
But I guess they still need something to limit their current since they are usually used in a low power solar garden light that does not have much current.
