Help with 15 Cell LiFePO4 Battery Charger
Ben12
Joined Mar 17, 2015
Hello folks,
I need help designing a 15 cell LiFePO4 Battery Charging System. I have no idea where to start. I've seen designs for 2-4 cell systems, is there a way I can expand those designs to operate on 15 cells in series? The cells are 3.2V nom with 100A/H. Ideally I'd like the charger to be a 2A charger.
This is a link to the type of cell.
http://www.ev-power.eu/Winston-40Ah-200Ah/WB-LYP100AHA-LiFeYPO4-3-2V-100Ah.html
Papabravo
Joined Feb 24, 2006
21,225
Well I recommend that you try doing two or four cells at a time before you tackle 15. As I understand the literature they want you to charge them individually.
ronv
Joined Nov 12, 2008
3,770
Seems like you should be able to do it.
You will need a 55 volt power supply with current limit and 15 balance modules.
Bernard
Joined Aug 7, 2008
5,784
I believe charging individually is for only the first charge. The statement on firse charge to connect all cells in parallel bothers me. For a $ 2133 battery, can not afford many mistakes. I did not see a suggested charging current but suspect for 100 Ah that 20 A would be in range; 2 A a little slow? A second or third reading might be in order.
Dodgydave
Joined Jun 22, 2012
11,301
according to the datasheeet they recommend optimal charging at 50 amps, for 2 hours, your 2 amp will take 50 hours, so your going to need a 55V 50 amp psu.
alfacliff
Joined Dec 13, 2013
2,458
one advantage of the lifpe04 batteries is that they dont need super critical charging systems. 4 cells in series can be used as a car battery, using the cars charging system with no modifications. other types of Li batteries can catch fire, explode, or other nasty things if charged wrong, just a little, but the life04 dont require specialized charging systems.
Ben12
Joined Mar 17, 2015
Thank you all for the responses. I think I'm going to start with charging 2 cells at a time with an active cell balancing system. If that works I'll see if I can expand it upwards incrementally.
