Help with 12V relay wiring.
Discussion in 'General Electronics Chat' started by WVUMath, Jun 18, 2013.
Thread Status:
Not open for further replies.
  1. WVUMath
    Jun 18, 2013
    Hello everyone, I'm new to the forum and this is my first post.
    I teach undergraduate mathematics at WVU, so hopefully no one thinks I'm a moron for not figuring this out on my own. It's a project i'm working on for a vehicle and can't seen to come up with the proper logic.
    I'm needing some help drawing up a schematic to work a DC motor. All relays and wiring are on a 12V circuit. I'm aware that a simple/typical power window circuit works on the follow logic.
    I am trying to use a single +12V input to active power to the blue wire off pin #30 on the left relay. The +12V input is controlled by the auto-down switch and thus stay's activated until the drivers window is completely down(assuming controlled via the motors current draw).
    I am trying to take this and apply it to my passenger window but am having no luck with my diagrams.
    I am trying to use the output of the auto-down function ( +12V) to activate a circuit to bring down my passenger window.
  2. WVUMath
    Jun 18, 2013
    My main concern is that the motors have no permanent ground. The rocker switch changes the polarity to reverse the motor and has stumped.
  3. Dodgydave
    Jun 22, 2012
    5,171
    778
    Assuming this is not closed as an Automotive project then..
    Your diagram is wrong , the coils are on pins 85/ 86, the wiper is pin 30, the NC is pin 87a, and NO is pin 87, so you have no +12V feed to the relay coils,this needs to be on pin 85
    Relay
    normally the relays will short out the motor until one is activated and then the motor will turn in that direction.
  4. Georacer
    Nov 25, 2009
    5,151
    1,266
    As I read this thread, it's about implementing an electrical window feature in a vehicle.
    This is a violation of the AAC forum rules, Chapter 6, on automotive modifications, as seen here:
    http://www.allaboutcircuits.com/l_tos.html
    Therefore, this thread will be closed.
    Please understand the reasons behind this action and bear no grudge.
    Feel free to tread on the rest of the forums.
    You may find answers to your questions in one of the links provided here: http://forum.allaboutcircuits.com/showthread.php?t=54400
    In case I interpreted your request wrongly, feel free to appeal this decision via a PM to any moderator.
Thread Status:
