Help wiring a 12V, 80VA transformer
Discussion in 'General Electronics Chat' started by punawele, Oct 1, 2013.
  1. punawele
    Oct 1, 2013
    I am making a power supply using a 12 volt, 80VA signal transformer with
    6 terminals on each the primary and secondary sides.
    How do I wire this? Which lug does the white wire go on and which lug does the black wire go on to achieve 24 volts secondary.
    All help greatly appreciated. Chuck, Kona, HI
  2. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
    Wow, TMI.
    But I can visualize it!
    Max.
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    This was neither feedback nor a suggestion, so I have moved it to a more appropriate forum.
  4. richard.cs
    Member
    Mar 3, 2012
    162
    31
    How about a photo of the transformer?
  5. punawele
    Oct 1, 2013
    Thanks, all, problem solved.
