Hello
I'm making a wake up light which will gradually turn on when a power is turned on.
The power source of this circuit is 9-12V, and each of the leds have standard (330ohms) resistors before them.
So my question is; Will the LEDs be okay and not burn out?
Because when i breadboarded the led to check its brightness by slowly turning the power up with a standard resistor before it, it burnt out when it reached about 3V.
Thank you
Thank you
