Help, what is single phase
Discussion in 'General Electronics Chat' started by Leo, May 11, 2004.
  1. Leo
    May 11, 2004
    6
    Hi, all:
    I am a programmer who got laid off, now I am trying to be an electrician. I know some of the physics about electronic. But in real life, there is a lot of which I don't know.
    For example, I understood that 3 phases has 3 wires. But, why is single phase can have 2 wires, are they synch or asynchronous???
    I dunno that you guys can answer this. If I am pulling 3 phases (A, B, C + W) 600 Amp power into a panel, does it means I can have total of 600 Amp breakers on each hot? Or I can only have total of 600 Amp breakers on all 3 hot wires??? (not consider about cont. load, you know, the 125%/80% stuff, or any other variations)
    Leo
  2. m4yh3m
    Apr 28, 2004
    186
    42
  3. Leo
    May 11, 2004
    6
    Thank you electricmayhem:
    I know how the 3 phases works. What I need to know is that why is single phase has two hots (A, B, +N) what phase they have on those wires.
    Leo
  4. Hamster
    Member
    Mar 16, 2004
    16
    Each hot line has a potential difference of 120 volts. Most house hold appliances run at 120v load. Some require 240 volts that is the reason for the second incoming wire. If you are truely interested in becoming an electrician I would suggest investing in this book National Electrical Code 2002 (softcover)
    Paul
  5. Leo
    May 11, 2004
    6
    Hi, Hamster:
    Thank you very much, now, that's closer to what I asked. See, in three phase power, it is basically a 3 core generator. Each differs at 120 degree. So, when it turns a complete cycle (1/60 sec), it would generate 3 diff phases of power output. Ok, now, every book I read, talks about 3 phases in detail. But, not one, not one book says why is it called single phase, but tow wires. Are the AC phases on these wires in sync or out of sync?? Are they 120 or 180 degree different???? Are those wires come from some source??? If they are, I can connect two wires together and still give me 120 V??? Or can I use single phase 1 wire setup (120 V) and connect to tow diff breakers and single 220 V outlets to connect that to a dryer????
    Yes, I got NEC, been reading that too (1999, because 2002 won't be in effect in a year or two). I read it about 1/4 through now. It only has regulations on that book, none of the basic stuff. So, I started going through some other books, some of them talk about basic stuff, but, ALWAYS skip the single phase stuff. I've bought 3 diff books and went through them now, no luck, so, HELP PLEASE :)
    Leo
  6. m4yh3m
    Apr 28, 2004
    186
    42
  7. Leo
    May 11, 2004
    6
    Thank you very much, electricmayhem .....
    This helps a lot. It clears some for me now. Sorry to keep bugging you guys. But, I tried the books and the Internet, and I can't find the help on my own. I really appreciated for the time that you guys wasted on me :p
    Now, the two wires that comes in, are they in phase? or they lags in some degree???
  8. m4yh3m
    Apr 28, 2004
    186
    42
    lol...oops...i just reported it to th emoderator... my bad...it's 3:29 AM and i'm sleepy...sorry guys. but yeah.... they lag 120 degrees.
  9. ollebula
    May 12, 2004
    6
    I'm pretty convinced that in an ordinary wall socket (two wires) one lead is zero and the other is alternating around it 230Vpp, but you never know which one it is. That means if you stick a wire in the socket it's only 50 % chance you will die. I reckon that could be called singel phase.
    olof
  10. Leo
    May 11, 2004
    6
    Thanks a lot guys :D
  11. Hamster
    Member
    Mar 16, 2004
    16
    Sorry I didn’t fully understand your question at first, but now I do. You know more than I assumed and I apologize if I came off harshly. I am just going to start from the beginning and make a few restatements. There are average measurements and peak to peak measurements. For AC distribution the average (rms) value is the common form of measurement.
    http://cipco.apogee.net/foe/fbaswc.asp
    In a three phase system the average power is raised by introducing an extra two wave forms. Each phase is 120 degrees out just like cutting a pie into 3 pieces. Each line has a potential difference of 120 Volts no relation between these two numbers. Or at least I don’t think there is.
    http://cipco.apogee.net/foe/frwt.asp
    Below link shows a phaser diagram (pie)
    http://www.kilowattclassroom.com/Archive/D...AWYEPhasors.pdf
    From how you stated your questions it makes me feel that you think these wave forms would have a canceling effect on each other. If that were true we would obviously loose all benefit from going to a system like this. Three phase powered devices are designed to take advantage of the three wave forms. A simple example would be an electric motor would have three isolated coils one for each phase to induce a magnetic field. The motor is doing just the opposite job as a generator.
    http://cipco.apogee.net/foe/fggtp.asp
    I am going on a gut instinct that the 3 wire (2 hots and neu) single phase system is just that single phase. So the neutral should be zero volts referenced to ground one hot should be 120 volts to ground and the other would be -120 volts.
    |-120 v <---------> 0 v <---------> +120 v|
    |hot 2________nuetral_________hot 1|
    |____________240v_______________|
    How the breakers terminate on the single phase panel is what determines the voltage on the circuit.
    More explanation can be found here.
    http://articles.findarticles.com/p/article..._51/ai_74293792
    poly phase
    http://www.allaboutcircuits.com/vol_2/chpt...t_10/index.html
    Electrical safety - neat stuff here
    http://www.allaboutcircuits.com/vol_1/chpt...pt_3/index.html
    Paul
  12. bipin
    Mar 21, 2004
    80
    Hi Leo,
    Check out this and c you get any thing new other than discussed so far.
    As you might know, Electrical supply voltages are different in different contries.
    Here in my place Line to neutral is 240V RMS. So, The Phase to Phase will be 240*1.732 = 415V
    (240* Square root of 3)
    A single phase supply will always have one Phase and one neutral, I dont understand the two hot wires that you are talking about. (are you talking about single phasing in motors? it is basically loosing of one phase and the loosing of power balance in the flux - which finally leads the motor to burn)
    In a three phase system the total effective current (The current which ultimately contributes the VA or Watt ) will be shared by each phase in a particular manner.
    ie, if you connect a motor which draws a current of 60 A, then each line current seperatly will be 60/root 3 ie,34A. (that tells you how you can connect a breaker.
    Suppose you connect your load in star connection and all of them are balanced you can c there will be no effect if you connect the neutral or not.
    ie, the return current will be shared by the other two phases for any of the phases.
    To understand the three phase well, I would sugest you to draw a three sine waves exactly 120deg appart with different colours and then analyse the rise and fall of voltage seperatly from 0deg to 480 deg.
    Best of luck.
    Bipin
  13. a880099
    Jan 16, 2009
    a house has a single phase service.its made up of 2 hot and a enutral wire .each hot wire will be about 120 to 126 volts,120 volts run lits and all 120 volt thongs like a toaster or hair drier ect and both wires that are 120 volts togather will run a electric stove or water heater,electric heat,ect.
  14. Wendy
    Mar 24, 2008
    20,772
    2,540
    Wikipedia has pretty good articles on 3 phase and power distribution.
    In the USA we use something called Split Phase for home use, which is different. Basically two 120VAC legs 180° from each other called L1 and L2. Taken together L1 and L2 is 240VAC, which is good for stoves, dryers, and other high power home appliences. It's been argued successfully at ACC that this is not called 2 phase.
