Help wanted
Discussion in 'General Electronics Chat' started by Tractortruck, Feb 20, 2015.
Thread Status:
Not open for further replies.
  1. Tractortruck
    Feb 19, 2015
    I'm looking to clip a 5v reference signal. Let me better explain my problem. I have a turbo diesel engine and I want to keep the PCM from seeing true boost pressure. The ideal circuit to wire in line of the signal would be adjustable and work as a voltage low pass filter.
    For example
    Signal range is .65 -4.65 volts. I only want .65- 3 volts. Is this possible?
  2. Reloadron
    Jan 15, 2015
    1,055
    275
    Unfortunately this forum has rules about automotive alterations and hacks. Discussions like this violate the terms of service as set by the forum owners. I would suggest you try another forum like this one which might be of some help.
    Ron
  3. Tractortruck
    Feb 19, 2015
    Sorry
  4. MrChips
    Oct 2, 2009
    12,652
    3,461
    The owners of All About Circuits have elected not to allow discussions of automotive electrical system modifications/enhancements due to safety concerns, the potential of legal ramifications and the possible circumvention of vehicle regulations at the state and federal level.
    This thread is against the AAC forum rules, Chapter 6, as seen here:
    This can be found in our Terms of Service (ToS)
    Here is a site that may provide you with some assistance: Electro Tech Online
    Good luck
Thread Status:
