Help wanted... lightning strike wreaks havoc on power supplies!
Discussion in 'General Electronics Chat' started by Capri335, Nov 29, 2014.
  1. Capri335
    Nov 29, 2014
    9
  2. GopherT
    Nov 23, 2012
    6,309
    4,030
    I assume this was just information that you wanted to share. Interesting and thank you for posting. Let us know if you have a question.
    I also like that the board was made by SKYNET Electronics! Considering SKYNET is involved, are you still sure it was lighting?
  3. Capri335
    Nov 29, 2014
    9
    Hi everyone, I am in need of some help to try to see if I can salvage a really good (and expensive to replace) machine that we were using daily.
    We got struck by lightning last week. It seems that every appliance that was plugged in (some switched on, but not all) have bitten the dust. In nearly every instance it has been the power supply to each appliance or machine.
    Most are replaceable and some already have been, but our large laminator is old and doesn't work. It doesn't have a separate power supply.
    We found a 240V 2A fuse on the input board (which I am assuming is a power supply). I couldn't find a matching fuse, so I drilled out the ends and used a 240V 2A wire from another fuse. I carefully soldered the wire in and replaced the fuse, BANG. It lit up like a flash light. That tells me that something else has failed. I am wondering what the most likely component to fail would be? The manufacturer is in the USA, this is a really old model and I am in Australia. I am wondering if there is a quick fix. Any ideas? see photo. Please note I am not an electronics person, I can tell a transformer from a resistor and capacitor, but I don't know electronics. As I used to wire up amplifiers I am sure that replacing components would be easy for me. Diagnosing the fault is really beyond me. I do have a multimeter (or two).
  4. Capri335
    Nov 29, 2014
    9
    I did have that there in the post first.... maybe I hit a wrong button!
  5. wayneh
    Sep 9, 2010
    12,386
    3,244
    For starters, that fuse looks blown.
  6. MaxHeadRoom
    Jul 18, 2013
    10,846
    2,521
    I am surprised it did not take the MOV (R1) out!. It is there to protect causes such as this.
    First check the Heatsinked power devices, worse case scenario, it can impose a short on one of the switching transformers.
    Max.
  7. GopherT
    Nov 23, 2012
    6,309
    4,030
    You cannot just solder in the wire from a working fuse. The glass and oxygen free partial vacuum is there for a reason.
  8. Capri335
    Nov 29, 2014
    9
    I said that I replaced it and it blew again.
  9. Capri335
    Nov 29, 2014
    9
    Ah OK, thanks I'll have to get to the electronics shop tomorrow. I thought that the glass was just an insulator. House fuses can be either way...
  10. GopherT
    Nov 23, 2012
    6,309
    4,030
    The big transformer in the center looks iffy. also, the chip in the center is an item that tends to fail. Sk8085 available on eBay from sellers in China for $5 to $10 with shipping.
  11. bwilliams60
    Nov 18, 2012
    734
    94
    Is it me or does VR1 look like it got pretty hot?
  12. GopherT
    Nov 23, 2012
    6,309
    4,030
    Either it got hot or it was trimmed at the factory and a low-quality epoxy was dabbed on to keep it in position.
  13. ISB123
    May 21, 2014
    1,240
    531
    That pot looks melted which probably means that large current passed through it which could mean that Voltage regulator is dead too.
  14. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    nevver heard of that
  15. takao21203
    Apr 28, 2012
    3,578
    463
    not entirely sure about that
  16. ISB123
    May 21, 2014
    1,240
    531
    You are right on one picture it looks like its melted but its actually glue.
  17. Capri335
    Nov 29, 2014
    9
    Yes it is just glue on that. Yesterday I managed to get another fuse (bought a pkt of 10), and it blew again. My feeling is that the transformer has probably gone. I am also guessing that it has to be de-soldered from the board before I can test it. I think that the logical thing would also be to NOT connect this board to the next one so that I isolate that probability of some component in the next board causing it.
  18. ISB123
    May 21, 2014
    1,240
    531
    This could be your problem marked in red circle,looks like pad fell off or its just weird reflection.
  19. JWHassler
    Member
    Sep 25, 2013
    204
    34
    That "input board" is a power-supply. It's way past time to declare a 'quick fix.'
    Figure out the required voltage/current and buy a new one. Don't waste any more time on trying to fix it.
  20. Capri335
    Nov 29, 2014
    9
    That's what I was wondering... if it is possible to replace this with another power supply. The only problem here is that I wouldn't really have a clue what to ask for or to order. I am guessing that the transformer lable holds the clue. 240V AC .5 amp in and 24V DC 1.3 amps out. There are only 2 wires into this and 2 wires out. As for working it out, that is a bit beyond me. The other board that it plugs into has no values on the input side, other than "DC".
