help w schematic drawing please anyone?
Discussion in 'Homework Help' started by gzeher, Nov 4, 2013.
  1. gzeher
    Nov 4, 2013
    motor control schematic drawing
    1. connect as low voltage 3phase motor
    2. circuit must be auto-jog control circuit
    3. auto mode after pressing start button, motor will start and continue to run
    4. in jog mode, motor will start when button is pressed stop when released
    5. when motor not running a green light is on
    6. use a float switch that stops motor when pushed up manually that starts a timer for 15 seconds and then motor goes in reverse
    7. use a stop button to stop circuit any time it is pressed
    8. motor is overload protected and low voltage protected
    that's it...im just having trouble drawing it from steps 5-8....any help would be greatly appreciated​
  2. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,509
