Have two kitchen outlets with GFCI that are passing full current but the "test-reset" is not working so I thought I should replace them. The old units are in a horizontal layout installed in a vertical pattern so I replaced them with the correct vertical units.
I carefully hooked them up just as the old ones were hooked up. Black to hot or brass screw and white to silver screw and ground to green. Turned on the power and nothing. I thought I may have switched the "Line - Load" so I carefully switched one black/white pair with the other black white pair of wires. Still nothing.
Using a tester I am getting 120v on one outlets white wires (one tester probe on one white wire and the other probe on the other white wire) Black to Black shows 3-4V.
The other receptacle shows 2-4V on any cross of wires.
What the heck is going on and what did I miss?
