Help: Using Multisim
Discussion in 'General Electronics Chat' started by SilverKing, May 16, 2014.
  1. SilverKing
    Feb 2, 2014
    72
    Hi everyone,
    I want to simulate the following two circuits in Multisim:
    The voltages on nodes 1, 2 and 3 should 80V, -64V and 156V respectively.
    But in Multisim:
    And if it's possible, guide me to any site or textbook showing how to simulate circuits in MATLAB or Simulink.
  2. Jony130
    Feb 17, 2009
    3,993
    1,116
    Your Multisim circuit is not the same as your original diagram.
    Ix current is a current that is flow through 4 ohm's resistor. But in Multisim I2 where is flowing ?
  3. SilverKing
    Feb 2, 2014
    72
    Isn't connected to 4 ohm's resistor? Please bear with me, I'm new to Multisim.
  4. crutschow
    Mar 14, 2008
    13,505
    3,376
    I think what Jony means is that the IZ control input of the current-controlled current-source must be in series with R3. You have it in parallel (effectively shorting out R3).
    If you post a larger graphic (not JPEG) of the circuit, it will be easier to see. Your posted circuit is rather fuzzy.
  5. SilverKing
    Feb 2, 2014
    72
  6. absf
    Dec 29, 2010
    1,493
    374
    Your I2 is in parallel with R2 which was wrong. I2 should be in series with R2.
    This is what Jony130 was saying.
    Allen
  7. crutschow
    Mar 14, 2008
    13,505
    3,376
    You do understand the difference between series and parallel, don't you?
