Help Using a 4060 As an Oscillator!
ro169
Joined Oct 10, 2014
62
Hi guys,
I know there are already several threads about the 4060, but I am still a bit puzzled. This is the first time that I'm working with the IC and I'm not quite sure if I'm simulating it correctly on Multi-sim.
I'm basically using the chip as an oscillator which will output a pulse to an amplifier which finally goes to a speaker. I've created a circuit which I gathered would work after reading the datasheet. From my understanding pins 1,2,3,4,5,6,7,13,15,14 are outputs. However I haven't observed any pulsating output on multi-sim.
Please see circuit below.
ro169
Joined Oct 10, 2014
62
Please note: In the uploaded circuit the oscillator channel B isn't grounded. It was when I was simulating the ouptut.
34,470
Oscillators can be temperamental when simulated and sometimes don't start.
Try the Use Initial Conditions (UIC) option.
ro169
Joined Oct 10, 2014
62
Hello again,
When I first posted this thread I had assumed that my connections/circuit may be wrong. However after spending some time trolling the National Instruments forums I have discovered that there was actually an issue with the clocking ability of the 4060 on multisim 9. Looks like they possibly haven't resolved this problem as yet. A member on the NI forum suggested alternatively simulating using the 4020 which is what I am going to do.
Any advice on the 4020, are there any advantages/disadvantages over the 4060, and should i consider not only using it in the simulation but when I'm actually building my circuit as well?
ro169
Joined Oct 10, 2014
62
Yes, discovered that whilst simulating.
Thanks.
I mainly require 2 clock pulses, 1 at 1Hz and 1 at 520Hz. The lack of an internal pulse in the 4020 would mean I'd have to use something like a 555 to generate an initial clock pulse. I fancied the 4060 as it would be driving a speaker and varying pulses from a single chip would have been quite useful.
ScottWang
Joined Aug 23, 2012
7,409
I would like to using CD4060 and crystal to generate a precisely 1Hz timebase, but if you like to generate 520Hz then you need another circuit, or a 512 hz from CD4060.
