HELP understanding JK circuit
Discussion in 'Homework Help' started by DaffyD, Sep 24, 2008.
  1. DaffyD
    Sep 24, 2008
    I don't understand how a JK flip flop series works. There is a series of 4 circuits all attached to a clock. The starting value is 0000.
    I need to trace it and tell what it does. Diagram is attached.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Hint: what will be the state of the Q and ^Q outputs at the initial state?
  3. DaffyD
    Sep 24, 2008
    Everything is set to 0 at start. I understand that but I don't even know how the circuit works.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Further hint - if the Q outputs are 0, what must the ^Q outputs be? What happens when you clock the flip flops based on the inputs?
  5. DaffyD
    Sep 24, 2008
    Okay, here is what I don't understand specifically. When the clock pulses, does it toggle J or K or both? Or does it toggle J on the rising edge and K on the falling edge? Thanks for your help.
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Have you looked at a truth table for a J-K flip flop? The state toggles based on the state of the J and K inputs. Get a data sheet for a 7472 to see how they work.
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
