I am trying to understand how to make this MOSFET work. Ultimately I want to use the current sense output to go to a comparator. If the voltage output that correlates with a max current I want the MOSFET to see, the comparator will pull the enable pin on the MOSFET driver low and shut down the MOSFET.
I am attaching three PDF files. The first is my try at a schematic without the comparator side of the schematic included. It is just how I am interpreting the AN10322 PDF, which is an app note for the MOSFET. The last PDF is the spec sheet on the MOSFET
My first question is do I have the schematic right?
Second question is about the RSense resistor value. What is n? I want to scale it so 50 amps is 5v.
Third question, I understand the first op-amp is converting amps to voltage (OA3b), whats the purpose of the other op-amp (OA4b)?
Finally is a OPA227 Op-amp a good part to use for this application?
