Help: TTL to Inverted TTL with two Outputs
Discussion in 'General Electronics Chat' started by Management, Nov 16, 2010.
  1. Management
    Thread Starter Active Member
    Sep 18, 2007
    306
    Is it possible to get two outputs (-5V and 0V [GND]) using a TTL signal?
    I was thinking maybe I can use two comparators. When the TTL signal goes high I get -5V at one output A and 0V at the other output B. When the TTL signal goes low I get 0V at output A and -5V at output B. Not sure how to proceed though.
    Any help would be greatly appreciated.
    Question: Can a comparator have -5V and GND as it's supply voltages for V- & V+ respectively.
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Yes. -5V isn't a TTL voltage though, so you are wanting something else.
    I have a decent two transistor circuit that does the job. Want me to look it up?
    Define your specs a little tighter though. TTL, for example, is typically +3.5V for a high and just under +0.7V for a low. What constitutes a high and a low for your new system?
  3. Management
    Sep 18, 2007
    306
    Hi Bill,
    In my system a high is 5V and a low is essentially 0V. If you could look that up it would be great. Below is what I desire of a circuit.
    At 5V TTL
    Output A: -5V
    Output B: 0V
    At 0V TTL
    Output A: 0V
    Output B: -5V
    I was thinking about using a comparator with GND at the positive supply and -5V at the negative supply. Is this feasible?
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  5. nomurphy
    Aug 8, 2005
    567
    12
    TTL (HCT, ACT, BCT, FCT to name only a few types) is positive logic where <0.8V is a low and >2.0V is a high, there are no negative voltages in TTL logic.
    You would need to generate a negative -5V supply (in addition to the standard +5V supply), and use transistors to do a level shift.
  6. Management
    Sep 18, 2007
    306
    It is only one TTL signal. Using this signal I need to have two outputs that switch using that TTL signal. Hopefully this makes sense.
    When the TTL goes high the two outputs have the above voltages, when the go low the swap voltages.
  7. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,382
  8. Management
    Sep 18, 2007
    306
    This is exactly what I want to do. Go from TTL to -5V and GND with a short propagation delay.
    I had a circuit that did that using this part:
    Link: http://www.nxp.com/documents/data_sheet/74HC_HCT04.pdf
    but the propagation delay is too long. So I need help doing it differently. With transistors, comparator.
    Need help.
  9. Ron H
    Apr 14, 2005
    7,050
    657
    What sort of loads will the outputs be driving?
    How much delay can you tolerate?
    Are your "TTL" levels coming from CMOS, or actual TTL logic? A TTL output does not go all the way to +5V.
  10. Management
    Sep 18, 2007
    306
    The TTL is coming from an actually TTL logic.
    The 0V & -5V will be driving a SPDT switch. So hence I need a driver circuit. The original driver circuit using the IC in my last post introduced too much delay.
    From the TTL to the actually switching of the switch it has to be less than 5ns. The switch switches in less than 1ns. So essentially I have a max delay of approx. 4 ns.
    Any ideas that can help me.
  11. Wendy
    Mar 24, 2008
    20,772
    2,540
    OK, the version I had was a negative to positive converter, so I redrew it. It was originally meant to do a negative logic system to printer interface, part of a light tree I had designed. The folks kept shifting the specs under me. I hate it when they do that.
    A simple diode on an op amp/comparator would do the same thing.
    I didn't do the two outputs because that is really basic, I figure you can take it from there.
  12. Ron H
    Apr 14, 2005
    7,050
    657
    I'm skeptical. What kind of SPDT switch switches in 1nS?
  13. Wendy
    Mar 24, 2008
    20,772
    2,540
    CMOS switch?
  14. Ron H
    Apr 14, 2005
    7,050
    657
    Yeah, I guess it could be, considering that he wants complementary drive signals.
  15. Management
    Sep 18, 2007
    306
    It is a Triquint FET Switch.
  16. Ron H
    Apr 14, 2005
    7,050
    657
    I've got a circuit for you, but I have a couple of questions:
    What is the risetime of your TTL input (what logic family are you using)?
    What is the input capacitance of your Triquint switch? Can you post a link to the datasheet?
  17. Management
    Sep 18, 2007
    306
    Is there any way for this to switch faster? I used this transiter circuit and it inverted in less than 5ns but when the TTL comes back down it has trouble going back up. Link: http://www.play-hookey.com/digital/experiments/ttl_inverter.html
  18. Management
    Sep 18, 2007
    306
    The rise time of the TTL input is 2.5ns (wasn't given the class). The switch is at the link below. I don't know the capacitance but the isolation is a little over 30dB. Will be like 40dB at the frequency of interest, i.e. 300MHz.
    Link: http://www.triquint.com/prodserv/more_info/proddisp.aspx?prod_id=TGS2306
  19. Management
    Sep 18, 2007
    306
    Any ideas around a comparator with complimentary outputs?
  20. Wendy
    Mar 24, 2008
    20,772
    2,540
    1 ns is a very small figure, if it were a freq it would 1Ghz. I suspect even a comparator is going to have problems with that number.
    It is in the realm of ECL, not TTL. ECL is a non-saturation logic, its logic levels are -0.7 and -2.0V, the basic circuitry is more like that of a differential amplifier. Their are TTL/ECL (and visa versa) converter chips out there.
    And yes, ECL can come with complementary outputs, since it is a kind of differential amplifier. Speaking of which, have you looked into making a differential amp?
