Ok Dave The signal on the 475A looks good nice square wave
However on the HP1740 Bad same as image I post at beginning
so the signal is working at TP9?Ok Dave The signal on the 475A looks good nice square wave
SO the fault is further in then, need to look at the next point which is page 117,The signal on the tek 475 works at tp9 ? yes
near Lydiate, i cant run too Fat!!Hey Dodgy, what parts of L'pool are you?
I know Woolton quite well. Ran around Calderstones Park many times.
When you find it look at pin3 ( input), and pin 18 (output),I see it on the schematic but not the board?
yes ,if you look on page 114 it shows where the ic is, looks like its on a separate pcb.Im looking for A5a1
Looks like its located on pcb A5 see page 53, the pcb is vertical mounted at the side of the crt.I will look on the other pcbs
Ok Im looking at the A5 PCB it has 4 adjustable pots . the only IC is a large white ic
located center of board. its an HP 624 chip it has 9 pins on each side . Im looking at the side towards the 4 pots
by Duane Benson
by Jake Hertz
by Duane Benson
by Jake Hertz
