help troubleshooting HP1740A oscilloscope
Discussion in 'General Electronics Chat' started by pastinsain, Sep 13, 2012.
  1. pastinsain
    Aug 25, 2012
    160
    Just picked up a HP1740A oscope and need to fix it. The problem is that
    it will not calibrate . I have the repair manual but you need a phd to understand it. So maybe someone could give some advice
    this is the image I get with volts set to .5 and time set main div .2
    I tryed to adjust the prob resistor but it has very little effect.
    When connected to a wavetek 180, can get a sine,triangle and square wave but only at high hf 1meg setting.
    Also the dc volt measure will not work. For example if connected to a nine
    volt bat it will not show the image. or any dc voltage. however, it will
    show the amplitude of a sine on hf.
    thanks for any help
  2. MrChips
    Oct 2, 2009
    12,648
    3,458
    There is a trimmer capacitor in the 10x probe, not a trim resistor.
    Make sure the probe is switched to 10x and adjust the trim capacitor.
  3. pastinsain
    Aug 25, 2012
    160
    I do have it set on 10X and tryed to adjust but that has very little effect.
    Its a tektronix probe. does that matter?
  4. MrChips
    Oct 2, 2009
    12,648
    3,458
    I suspect your probe is faulty.
  5. crutschow
    Mar 14, 2008
    13,508
    3,385
    Try doing the measurement directly using a wire (coax preferable) without the probe.
  6. Dodgydave
    Jun 22, 2012
    5,159
    772
    is your scope set to AC instead of DC input?
  7. pastinsain
    Aug 25, 2012
    160
    Ive tryed 4 different probes all the same. One of the probes is just a bmc with two
    clips. all wire no caps. all the same
  8. Dodgydave
    Jun 22, 2012
    5,159
    772
    I think your scope is on AC and should be DC
    as you said it wont measure your 9Volt battery!!!
  9. pastinsain
    Aug 25, 2012
    160
    The scope is set on dc but ac or dc same result.
    But when its connected to the function generator, it works on sine,triangle and square at 1mhz settiing but the square is lost as you turn the freq down. and no DC output at any setting. however, the sine stays displayed as you slow the freq and the triangle will get distorted as well at low freq.
    the generator works perfect with the Tektronix 475a. so its not that
  10. Dodgydave
    Jun 22, 2012
    5,159
    772
  11. pastinsain
    Aug 25, 2012
    160
    Yes same on both channels .
    yes thats the one
    yes Dave thats the one. HP1740A
  12. Dodgydave
    Jun 22, 2012
    5,159
    772
    Well , unless you have the settings wrong , it must be the scope at fault?
    Can you input a sine wave at different frequencies,at 1vpk, 1Khz, 10Khz, 100Khz, 1Mhz into both channels separately AC then DC,
    then try it on square,
  13. pastinsain
    Aug 25, 2012
    160
    Absolutley the scope got a problem. now its a boat anchor. I will have to wade though the service manual on this one.
    I did take the covers off and its got old original power caps. and one the the power board capacitors had been replaced at one time .Also, a rectifier was replaced looked somewhat of a hack butcher job. I have not taken the test voltages as of yet
  14. Dodgydave
    Jun 22, 2012
    5,159
    772
    OH DEAR! have you got the schematics?
  15. pastinsain
    Aug 25, 2012
    160
    dogdydave I have tryed every conceivable configuration but still no resolve.
    It will not take low volt dc test That distortion you see in the example screen shot
    is the dc and ac result. I just hope its not a proprietary chip thats gone south!
  16. MrChips
    Oct 2, 2009
    12,648
    3,458
    Without studying your situation more carefully, I suspect your scope is measuring AC and not DC. Hence the problem is in the AC-GND-DC switch. Try switching it back and forth many times to try and clean the switch (or use a contact cleaner).
  17. pastinsain
    Aug 25, 2012
    160
    Yep I got all the schematics and service manual in pdf format.
    I need to know what board it need to look at?
    Power supply?
    it could be anyone of five or so boards.
  18. pastinsain
    Aug 25, 2012
    160
    The ac -gnd-dc switches on both channels are the same so I dont think its the switches. The interior and boards are very clean with no visible problem. The scope looks in excellent condition.
  19. pastinsain
    Aug 25, 2012
    160
    Mrchips I will try a litlle CRC contact cleaner on the ac-dc switches and see what
    happens.
    Well I took the cover off and there is no way to get to the back ac-gnd-dc switches. without major surgury.
    It looks like it would take days to get to them. providing I did not damage somthing else in the process.
  20. Dodgydave
    Jun 22, 2012
    5,159
    772
    look where the inputs go to, there will be a common circuit that these inputs use , any chance you can post the pdf?
