I have a Topaz 32 mixing console.
The regulated power supply has 4 wire output 48v +17v -17v and AGDN
The mixer has 3 leds lights for each output except -17v led is not turning on. Hence the mixer is not working and no output is coming out
As per manual if one is not working then there is an issue with your power supply
Here is what I notice.
If all the power output is connected to the mixing board, -17v led light is off and mixer will not work.
If I take out the AGND line, all the led lights turns on and the mixer will work fine.
Wondering what is wrong
