Hi there.
Thanks for reading my post, So I have created a schematic and have produced a few boards for testing, in terms of what it does it uses a 9DoF chip and an atmega chip to provide information about position/rotation.
So I had an issue with the first one where the atmega chip did not respond to anything when programming it with bootloader, I then got a second one created and I still have the same issue.
The atmega chip is not responding and checking the clock signal there is nothing at all, I check the usb-serial IC and that has a clock signal, but nothing on the atmega.
I am not sure if I have missed anything, but looking at this schematic, I have checked the documents for that IC and everything seems to be connected correctly also I have followed other designed that use the atmega to make there own arduino device
