Help transistor switch
Discussion in 'The Projects Forum' started by kenny-one, Oct 14, 2012.
  1. kenny-one
    Apr 21, 2010
    37
    Hi guys
    I designed the attached transistor switch, the problem with it is that the negative part of the output does not reach the set amplitude(4.5v) unlike the positive part.
    How the circuit works: the Vcc switches the Vdc on and off. In on position, Vcc allows two cycles(two oscillations of Vdc) to pass.
    Anything im missing here?
      File size:
      104 KB
      52
      File size:
      288.9 KB
      31
  2. crutschow
    Mar 14, 2008
    13,477
    3,362
    An NPN transistor can only have positive voltage on the collector. You are applying plus and minus voltages. You must add a +4.5V offset to the AC voltage so it goes between 0V and 9V positive voltage.
  3. kenny-one
    Apr 21, 2010
    37
    thanks for your reply. But how do I offset the voltage?
  4. ScottWang
    Aug 23, 2012
    4,925
    777
    You can see the following info, it will help you more understand about the double power used in Amplifier.
    Class B audio amplifier.
    http://www.allaboutcircuits.com/vol_6/chpt_6/10.html
    Also you can use the search engine of All About Circuits to searching by : Class B audio amplifier.
  5. donpetru
    Nov 14, 2008
    186
    25
    See attached image below.
  6. kenny-one
    Apr 21, 2010
    37
    I still cant get anything ut if this. It seems like is quite difficult to do this offset thing, since nobody seems to be coming with a precise solution.
    How do i go about doing it?
  7. absf
    Dec 29, 2010
    1,493
    374
    To offset the sine wave by 4.5V on the simulator is easy. Just change the VDC "sine (0 4.5 40k 1n 1n)" to "sine (4.5 4.5 40k 1n 1n)".
    In real circuit, you need a DC of 4.5V super-imposed with sine wave of 4.5V amplitude on the VDC.
    Allen
  8. kenny-one
    Apr 21, 2010
    37
    yes, coz i have designed a wein bridge oscillator that gives around 4.5 Vp. so what circuit would enable me to shift it to 0-9v?
  9. crutschow
    Mar 14, 2008
    13,477
    3,362
    Use a series dc-block capacitor to couple the signal into a resistor divider to bias the transistor. See this.
  10. MrChips
    Oct 2, 2009
    12,624
    3,451
    What you need is a linear gate such as an FET or CD4016/4066.
  11. kenny-one
    Apr 21, 2010
    37
