Help Transistor MOSFET replacement
Discussion in 'The Projects Forum' started by ChrisChemist116, Jan 13, 2011.
  1. ChrisChemist116
    Thread Starter Active Member
    Mar 13, 2009
    78
    Howdy,:)
    I came across this schematic (http://pfranc.com/pclink/myidea.htm) to build a CASIO DATA cable for calculator CFX9850.
    Everything seems to be in the right order. Except the MOSFET transistor.
    One site (http://www.casiocorner.com/data/html/modules.php?name=News&file=article&sid=13) suggests to use ZVP 3306 or VP0106 (altough it tells the model as SiVP 01069602). (I think it is Mosfet P channel).
    I can't find any of these in my location. Is there any equivalent easier to find?.:confused:
    Bellow you can see the schematic. Middle, Bottom and Tip, are Ring, Base and Tip in 2.5 mm audio plug.
    Best regards~
  2. CDRIVE
    Jul 1, 2008
    2,223
    99
    If it's a real serial port and not a USB/Serial converter, you will have ~ +- 12V at all the serial port pins. This circuit will not demand much current, so you don't need a power FET. Honestly, probably many small PMOS FETs will work here. That said, it's late and I haven't really taken a good look at this circuit..tomorrow.
    Before you dive into this though, remember that unless you're very experienced you can fry your serial port if you make a wiring mistake. If your UART is on the mother board (not a card), the damage could be catastrophic. The Max232 is a RS232 interface chip and is what's widely used for RS232 to 5V logic levels.
  3. ChrisChemist116
    Mar 13, 2009
    78
    Alright i understand what you say. But i would appreciate if you could suggest me a replacement as there are many FETs out there. As what you can see from the schematic, is there any particular model do you suggest? :rolleyes:
    And regarding to the serial port. I see no problems at all, and i think i can give it a try.
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    What distributors do you use? RS Components? Farnell UK?
    Without knowing what distributors you have access to, we could play "Guess the MOSFET" quite a bit before finding one that's suitable.
    Basically, you're looking for a P-ch enhanced MOSFET in a small package, preferably TO-92, that's rated for a Vdss of -30v to -60v, low gate charge (<3nC) and Id in the range of -10mA to -500mA; it doesn't have to be much.
  5. CDRIVE
    Jul 1, 2008
    2,223
    99
    Can you get a 2N7000 by you?
    EDIT: This is a N-Chan MOSFET. The OP is needing a P-Chan.
  6. thatoneguy
    Feb 19, 2009
    6,357
    718
    That's an N-Channel, Useful small purpose MOSFET though.
    I've used the ZVP2106 as a "compliment" to the 2N7000 with semi-OK results. The Rds ON is a bit on the horrible side, but it is logic level P MOSFET in TO-92 case.
  7. CDRIVE
    Jul 1, 2008
    2,223
    99
    Oops, my error!
  8. ChrisChemist116
    Mar 13, 2009
    78
    Okay Sarge. I was thinking about that. The closest distributor to my location is Futurlec. And judging from what i can see, it carries transistors among other components within JEDEC standards.
    It would be helpful if the replacement it is in such category.
    Sidenote: I have to say the first time i read your answer "guess the Mosfet" let me :D But i know what you mean.
    With that said, is there any Mosfet you suggest i can use within the range you specified and in TO-92 package on JEDEC?:rolleyes:
    Yes i can get 2N7000, but as said above it would be useless as i require a P-Chan Mosfet.
    I would be happy to give a try to ZVP2106 but i can't find it. Is there any equivalent on JEDEC or any other choice i can try?.:(
    Dont be worry, such things happens.:)
