Help! Touchscreen Directory
Discussion in 'The Projects Forum' started by jjuurreell, Oct 3, 2012.
  1. jjuurreell
    Sep 9, 2012
    23
    I found myself stupid asking those previous questions, so after researching some ideas , this is the real problem we have so far..
    does a single pic microcontroller can make a touchscreen building directory? can it make image as an output in the touchscreen panel ?
    if no... what do we need to make images? a CPU? a motherboard?
  2. ErnieM
    Apr 24, 2011
    7,438
    1,626
  3. jjuurreell
    Sep 9, 2012
    23
    can it store images? i was thinking it cannot hold large data since memory is limited. am i right about this?
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Yes and no. If you are talking about just the memory physically located on the chip with the processor -- then the answer is no.
    If on the other hand an SD Card, or a USB Thumb Drive is available to the PIC then the answer is Yes.
    As with all things on the forum you need to clearly articulate your assumptions when you ask a question.
  5. jjuurreell
    Sep 9, 2012
    23
    sorry about asking that, so last question, can i make a building directory with just the pic microcontroller, processor and the external memory?
    thanks!
  6. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Yes, you can.
