help to replace tacho generator
Discussion in 'The Projects Forum' started by ss.achary, Oct 28, 2015.
  1. ss.achary
    Oct 27, 2015
    28
    I would like to replace an dc motor tachogenerator with encoder... But the motor is controlled by drive which has only tacho input for feed back... So I have to fix an encoder with analog output... Tacho spec: 10v/1000rpm..
  2. ss.achary
    Oct 27, 2015
    28
    What type of circuit should I use to modify it...
  3. MaxHeadRoom
    Jul 18, 2013
    10,833
    2,502
    I assume you have an older DC drive that has a DC tach feedback, an encoder is generally digital, what context are you using the drive in? Simple open loop velocity drive or do want or need to control it with a PID loop etc?
    Max.
  4. ss.achary
    Oct 27, 2015
    28
    I would like to modify an encoder with analog output similar to tachogenerator... This should work in DC drive that has a DC tach feedback...
  5. MaxHeadRoom
    Jul 18, 2013
    10,833
    2,502
    Incidentally DC tach's are no longer used in current positioning drives, there is a single PID loop that is returned to the trajectory planner or control, typically using torque mode rather than velocity mode control.
    So if I understand you correctly, you want to use a DC tach as an encoder of some kind?
    Is this an existing system or are you designing something?
    The full story helps, including any details of present equipment.
    Max.
  6. ScottWang
    Aug 23, 2012
    4,925
    777
    The tachogenerator is output an analog voltage, but the encoder output two phase pulses, so you may need two sets of F to V(the Frequency-to-Voltage converter), those provided two directions as forward and reverse, if you don't need the reverse then you just need one set of F to V.
  7. ss.achary
    Oct 27, 2015
    28
    WP_20151029_12_36_29_Pro.jpg motor used in our machine
  8. ss.achary
    Oct 27, 2015
    28
    Above is the drive used
  9. ss.achary
    Oct 27, 2015
    28
    Please provide me full block diagram for it... Encoder - decoder - up/down counter-f/v converter
  10. ss.achary
    Oct 27, 2015
    28
    WP_20151029_12_34_28_Pro.jpg motor
  11. ss.achary
    Oct 27, 2015
    28
  12. ss.achary
    Oct 27, 2015
    28
    WP_20151029_12_35_13_Pro.jpg use this encoder instead of tacho... And connect the output of encoder to the same drive... I need help in replacing it....
  13. ss.achary
    Oct 27, 2015
    28
  14. ss.achary
    Oct 27, 2015
    28
    wp_ss_20151029_0001.png this is hctl2000 ic can I use this ... How can I make to analog....
  15. ScottWang
    Aug 23, 2012
    4,925
    777
    You can see the encoder pulse, you have to design a pulse detector for encoder forward and reverse, maybe the output as A = pulse, B = low when the encoder forward, and the output as A = low, B = pulse when the encoder reverse.
    Source.
    And the output of your block diagram, the output of F/V as two 0~5V, how do you use these two voltages to control the motor?
  16. ss.achary
    Oct 27, 2015
    28
    Please provide me a alternative method...
  17. ss.achary
    Oct 27, 2015
    28
    wp_ss_20151029_0002.png can I use this to detect pulse...
  18. MaxHeadRoom
    Jul 18, 2013
    10,833
    2,502
    I doubt you are going to be able to use that quadrature encoder to input to the drive, you would need to convert to a linear analogue signal.
    Is there any reason you are not using the original tach, if built in and is defective, it will be easier to fit an external DC tach, I have done this in the past.
    Max.
  19. ss.achary
    Oct 27, 2015
    28
    Sir the tacho coil is costlier... If I use encoder it would be less cost and easy to fix it in motor...
  20. MaxHeadRoom
    Jul 18, 2013
    10,833
    2,502
    Have you tried a small (cheap) DC motor ran as a generator, which is all the tach is anyway, just a refined one, if the original tach was 10v/1krpm then a DC motor with the same voltage should work.
    i.e. 20v motor @2000rpm.
    Most drives have a pot to calibrate the tach to fine tune it.
    Max.
