OK, I have a 30 gallon aquarium that has a sump. I had no protection to prevent the tank from over following when the overflow sponge got to clogged. So I had to clean up about 10 gallons of water today.
I want to design a circuit that when a level switch goes low the pump turns off (I have this part down pat). My issue with the design (or where I am stumped) is once the level switch goes low I do not want the pump coming back on with out an acknowledgement of some sort.
Any thoughts will be appreciated.
The attached is what I have and it works if I did not want the acknowledgement.
