I have to add a voltage between 3 to 7mv to the inverting input. am I right? What is the simplest way to do it? is there any way to add a circuit or part to do it automatically? like an auto-zero-derift Op-Amp.You have found that there is a small (within tolerance) positive offset voltage. In other words the opamp behaves as though its non-inverting input is slightly above its inverting input, even when it really isn't. So how do you think you can adjust an input to compensate that?
1) You're right.am I right? What is the simplest way to do it? is there any way to add a circuit or part to do it automatically?
by Aaron Carman
by Jake Hertz
by Aaron Carman
by Duane Benson
