Help to Identify this IC Chip
Discussion in 'General Electronics Chat' started by dutchgin, Mar 22, 2013.
  1. dutchgin
    Mar 22, 2013
    HI everyone,
    Does anyone know what IC this is? I tried looking up the numbers but to no avail.
    Thanks.
  2. MrChips
    Oct 2, 2009
    12,623
    3,451
    This is a Microchip microcontroller such as a PIC12F508-I/P which has been programmed for a specific application.
  3. dutchgin
    Mar 22, 2013
    Thank you Mr. Chips. Is there any way to read and copy the programming to another chip? The chip is on a board that runs an ultrasonic transducer.
  4. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    How can you tell? I can't read the part numbers.
  5. MrChips
    Oct 2, 2009
    12,623
    3,451
    screen1988 and DerStrom8 like this.
  6. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    That's funny, every time I see you post, I picture a frog opening a bag of Lay's :D:D:D
    screen1988 likes this.
  7. ErnieM
    Apr 24, 2011
    7,434
    1,625
    Me neither, but he DID say "such as."
    The schematic looks like a 555 timer to me.
  8. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    True.
    The reason I knew it wasn't something like a 555 was because of the pin numbers and connections. None of the pin numbers would match the components connected to them if it was a 555 timer.
  9. MrChips
    Oct 2, 2009
    12,623
    3,451
    Do some reverse engineering. If you had to create such a function which chip would you use?
    DerStrom8 likes this.
  10. takao21203
    Distinguished Member
    Apr 28, 2012
    3,577
    463
    When it is sold as seen here, what you want is probably illegal.
    A copy protection bit does not only have the purpose to prevent actual copying. It also clearly makes any such attempt or action illegal.
