help to identify src
Discussion in 'The Projects Forum' started by markosillypig, Jan 4, 2013.
  1. markosillypig
    Thread Starter Active Member
    Jul 21, 2008
    184
    hi all and happy new year.
    could any one help ?
    I bought this simple 2000W AC 50-220V 13KHZ regulator Motor speed control controller off ebay but the crafty 2@ts have sanded out the part number so need help to identify it.
    • Working Voltage: AC 50-220V
    • Control Power: 2000w
    • Static Current: 0.02 A ( Standby )
    • SCR Duty Cycle: 10% -100%
    • SCR Frequency: 13 KHz
  2. Dodgydave
    Jun 22, 2012
    5,147
    769
  3. tubeguy
    Nov 3, 2012
    1,157
    197
  4. THE_RB
    Feb 11, 2008
    5,435
    1,305
    It can;t use a TRIAC or SCR at 13kHz, it's probably a IGBT transistor as a PWM driver.
  5. BillB3857
    Feb 28, 2009
    2,402
    348
    Can you post other views of your board? I really don't see where the 13kHz can be coming from. I do see what may be a diac (blue component near heat sink at right side). This would indicate Triac control at line frequency.
