Help to Identify SMD part!...
Discussion in 'General Electronics Chat' started by nieves32, Feb 25, 2013.
  1. nieves32
    Feb 25, 2013
    Hello Forum!
    I ask for your help please to identify this SMD parts with the ledgend "GGG 72A" I think that there are a Diodes, but I do not know wich are. The circuit is a Poe injector.
    Thanks in advance for your help!...
    Best regards!...
  2. sheldons
    Oct 26, 2011
    616
    101
    they are both diodes
  3. t06afre
    May 11, 2009
    5,939
    1,222
    Yeah...but what kind of diode is it. That would be a lot more helpful:rolleyes:
  4. t06afre
    May 11, 2009
    5,939
    1,222
    I recognize the white components as Comgap gas discharge tube (GDT) surge
    arrester devices. Has used them my self in medical devices. I also recognized the symbyl on the SMD as a symbol used on components from Vishay. That lead to that the components probably was some kind of transient voltage suppressors. And indeed that was correct The GGG is the type marking. And since it has no markings it is bi-directional
    http://www.vishay.com/docs/88394/88394.pdf
    http://shpat.com/docs/elfa/06050009.pdf
  5. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Looks like they go from the two power rails to the ground plane, it's really unlikely they are rectifier diodes.
    My guess is that (like the two gas arrestors) they are some type of transient protection, like transorbs or even MOVs.
  6. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    Measure them with a DMM continuity tester. Schottky give some 110 to 200mV. Regular diodes- 500mV.
    Coils give nearly zero Ohms.
  7. praondevou
    Jul 9, 2011
    2,936
    489
    bi-directional Transorbs have a CA suffix.
  8. t06afre
    May 11, 2009
    5,939
    1,222
    Oh thank you pointing that out. Important then ordering. But I do not the CA suffix is icluded on the SMD package. To me it looks like they use band/no band
