Hi These unusual looking parts are on a transmission control unit for a tractor early 90's design. Any suggestions what they might be. Looks like some sort of custom design.
Label is JJ675-69425 and JJ675-694426
The board has standby voltage but is not generating the signal to switch on the main 5v supply. I need to remove the board but these components are screwed and look to be glued in. Unfortunately waiting on small screw removable kit as screws are not opening and will need to drill out.
