help to identify part please
Discussion in 'The Projects Forum' started by markosillypig, Nov 10, 2009.
  1. markosillypig
    Thread Starter Active Member
    Jul 21, 2008
    184
    hi can any one help to identify this part it has no writing on the side
    the circuit board is for a simple 4 light 240V light sequencer sound activated as well
  2. BMorse
    Sep 26, 2009
    2,675
    234
    from what I can tell and where it is located on the circuit (+VCC), I would say it is a fuse for the transistors/Mosfets....
    My .02
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    I would say that the black stripe identifies it as a jumper, dressed up as a zero ohm resistor. The ones I use have beige phenolic bodies, but the stripe is the same. Classier than clipped off resistor leads.
  4. thatoneguy
    Feb 19, 2009
    6,357
    718
    It is a jumper, what BeenThere said.
    Machine component placing makes it easier to put in a resistor shaped object than a bare wire. So, they coat a bare wire with a resistor shape, put a single black band on it, and use that instead.
