HELP to convert serial MATLAB code into PARALLEL and then into CUDA
Discussion in 'Homework Help' started by Erevos, Nov 3, 2011.
  1. Erevos
    Nov 3, 2011
    Hi everybody, i have to do a homework which simulates fire spreading and the quest is; convert serial matlab code to parallel and then into CUDA (GPU computing). The serial matlab code is :
    _________________________________________________________________
    function celluralFire292(fire_spots, time_steps, CAwidth, CAheight, noDynamics)
    %2D Cellular Automaton For Fire Simulation
    % 'time_steps' are the number of steps to simulate.
    % 'fire_spots' is the number of initial fire spots.
    % 'CAwidth' and 'CAheight' are the width and height of automaton,
    % respectively.
    % 'noDynamics' makes everything homogeneous
    % FIRST STEP. CHECK INPUT ARGUMENTS FOR VALIDITY
    % Check number of arguments.
    if (nargin > 5)
    error('Way too many arguments passed to function!');
    end
    close all; %close open figures
    % Fill in potentially unset optional values with default ones.
    if (nargin <1)
    fire_spots=3;
    end
    if (nargin <2)
    time_steps=300;
    end
    if (nargin <3)
    CAwidth=120;
    end
    if (nargin <4)
    CAheight=120;
    end
    if (nargin <5)
    noDynamics=false;
    end
    %Check fire_spots
    if isempty(fire_spots)
    error('Invalid input parameter fire_spots (empty)!');
    end
    if (~isscalar(time_steps))
    error('Invalid input parameter fire_spots. Must be a scalar value!');
    end
    if (~isnumeric(fire_spots))
    error('Invalid input parameter fire_spots. Must be a numeric value!');
    end
    if ( fire_spots<1)
    error('Input parameter fire_spots out of range. Valid values greater or equal to 1!');
    end
    %Check time_steps
    if isempty(time_steps)
    error('Invalid input parameter time_steps (empty)!');
    end
    error('Invalid input parameter time_steps. Must be a scalar value!');
    end
    if (~isnumeric(time_steps))
    error('Invalid input parameter time_steps. Must be a numeric value!');
    end
    if ( time_steps<1)
    error('Input parameter time_steps out of range. Valid values greater or equal to 1!');
    end
    %Check CAwidth
    if isempty(CAwidth)
    error('Invalid input parameter CAwidth (empty)!');
    end
    if (~isscalar(CAwidth))
    error('Invalid input parameter CAwidth. Must be a scalar value!');
    end
    if (~isnumeric(CAwidth))
    error('Invalid input parameter CAwidth. Must be a numeric value!');
    end
    if ( CAwidth<5)
    error('Input parameter CAwidth out of range. Valid values greater or equal to 5!');
    end
    %Check CAheight
    if isempty(CAheight)
    error('Invalid input parameter CAheight (empty)!');
    end
    if (~isscalar(CAheight))
    error('Invalid input parameter CAheight. Must be a scalar value!');
    end
    if (~isnumeric(CAheight))
    error('Invalid input parameter CAheight. Must be a numeric value!');
    end
    if ( CAheight<5)
    error('Input parameter CAheight out of range. Valid values greater or equal to 5!');
    end
    %Check noDynamics
    if isempty(noDynamics)
    error('Invalid input parameter noDynamics (empty)!');
    end
    if (~isscalar(noDynamics))
    error('Invalid input parameter noDynamics. Must be a scalar value!');
    end
    if (~islogical(noDynamics))
    error('Invalid input parameter noDynamics. Must be a logical value!');
    end
    %TRUTH AT LAST. START CODING CELLURAL AUTOMATON
    width=CAwidth;
    height=CAheight;
    C=zeros(width,height); %cell states. Initialized to zero (non-burning)
    %initialize fire spots
    if (fire_spots==1)
    C(floor(width/2),floor(height/2))=1; %a fire spot
    else
    spots_i=randi([2,width-1],1,fire_spots);
    spots_j=randi([2,height-1],1,fire_spots);
    for k=1:fire_spots
    C(spots_i(k),spots_j(k))=1; %a fire spot
    end
    end
    %height coefficients
    H=zeros(width,height);
    x=1:width;
    y=1:height;
    H=10+0.13*(sin(5.5*pi*x/width)')*sin(7.2*pi*y/height);
    H=H+1.1*(sin(1.5*pi*x/width)')*sin(1.2*pi*y/height);
    H=H+0.2*(sin(1.12*pi*x/width)')*sin(1.3*pi*y/height);
    H=H+0.15*(sin(0.2*pi*x/width)')*sin(0.52*pi*y/height);
    %Temperatures spatial coefficients.
    Fuel=1+0.2*randn(width,height);
    Fuel=Fuel- min(0,min(min(Fuel)) );
    Fuel=Fuel/max(max(Fuel));
    if ~(noDynamics)
    jk_greenmap=[0.1, 0.4, 0.1; 0.1,1,0.1]; %maps 0 to black and 1 to green
    surf(x,y,H,Fuel);
    colormap(jk_greenmap);
    title('Topology and Vegetation');
    end
    %Wind coefficients with respect to each neighbor
    W=zeros(3,3);
    windStrength=0.4; %0 to 1
    windVec=[1,1]; %(x,y) coordinates of end point. Start point assumed (x,y)=(0,0)
    %weights of neighbors proportional to projection of
    %wind vector to the neighbor's direction
    for m=-1:1
    for n=-1:1
    nVec=[m n]; %vector pointing to neighbor
    nVec=nVec/norm(nVec); %normalize length for fairness
    W(2+n,2-m)=windStrength*nVec*(windVec')/norm(windVec); %dot product. Depends on wind length and angle
    end
    end
    %distance weights (for circular distribution)
    DIS=ones(3,3);
    DIS(1,1)=sqrt(2);
    DIS(1,3)=sqrt(2);
    DIS(3,1)=sqrt(2);
    DIS(3,3)=sqrt(2);
    % Cellural Automata Output Movie - Intialization to zeros.
    movie_out = zeros(width, height, time_steps);
    movie_out( :, :, 1) = C; %initial output state
    %I assume that the boundary of te used tables are dixed
    %boundary conditions. Automaton is defined within this boundary.
    disp('PATIENCE MY FRIEND!');
    % CELLURAL SIMULATION. I HAVE NO CLUE WHETHER THIS IS WHAT
    % YOU WERE ASKING FOR, BUT IT IS A CELLURAL AUTOMATON
    % ANYWAYS (ALL RULES ARE LOCAL, both for updating Cnew and Rnew)...
    stop_frame=time_steps;
    Cnew=C;
    for k = 2:time_steps
    stop_simulation=true; %used to stop simulation when all burned or stable...
    %simulate everything but boundary
    for i=2:width-1
    for j=2:height-1
    if (C(i,j)==1) %skip if totally burned
    continue;
    end
    %update CA
    Cnew(i,j)=0;
    %iteratively apply rule using all neighbors
    for m=-1:1
    for n=-1:1
    %update neighbors weight
    if (m==0 && n==0)
    if (noDynamics)
    R=1/9;
    else
    R=1/9;
    end
    else
    if (noDynamics)
    R=4/(9*DIS(2+m,2+n));
    else
    Hdiff=1+( H(i,j)-H(i+m,j+n) );
    R=1.4*(1+Hdiff*Fuel(i,j)*W(2+m,2+n))/(9*DIS(2+m,2+n));
    end
    end
    Cnew(i,j)=Cnew(i,j)+R*C(i+m,j+n);
    end
    end
    %make sure you update
    if ( ( Cnew(i,j)- C(i,j) )< 0.1 )
    Cnew(i,j)=C(i,j)*1.1;
    end
    %make sure you do not exceed 1.0
    Cnew(i,j)=min(1,Cnew(i,j));
    if ~(Cnew(i,j)==1)
    stop_simulation=false;
    end
    end
    end
    C=Cnew;
    movie_out:),:,k)=C; %update current state array for next iteration
    if (stop_simulation )
    stop_frame=k;
    break
    end
    end
    % FINAL STEP. PLOT THE OUTPUT AS MOVIE.
    figure;
    %plot and captute every frame of the simulation output
    for n=1:stop_frame
    jk_colormap=[1,1,1;0.2,0.2,0.2]; %maps 0 to white and 1 to black (dark gray)
    %pcolor(cellural_out);
    %imshow(cellural_out, 'InitialMagnification', 100);
    imagesc(movie_out:),:,n)); %image values scaled automatically
    %colormap(jk_colormap);
    axis ij; %places the coordinate system origin in the upper left corner
    % The cell array ( {...} ) in title is used to write separate lines...
    title(['\...}']);
    text(3,3,['\color[rgb]{0 .3 .6}Time Step: ', num2str(n) ] );
    set(gca,'XAxisLocation','top');
    axis image; %keeps relative dimensions of axes proportional to image size
    %capture and store current plot frame
    M(n)=getframe;
    end
    figure;
    imagesc(movie_out:),:,2));
    figure;
    imagesc(movie_out:),:,50));
    figure;
    imagesc(movie_out:),:,100));
    % %%CREATE A MOVIE FROM FRAMES
    % desired_playback_time=7.0; %desired playback time in seconds (approximately)
    % fps=(round(1.0*stop_frame/desired_playback_time));
    % fps=max(1,fps); %make sure its higher than 1
    % fps=min(25,fps); %make sure its less than 50
    % fps=min(fps,stop_frame); %make sure its less than stop_frame
    % movie(M,1,fps);
    %Save output to a movie file. Quite problematic...
    %movie2avi(M, [imageName , '.avi'], 'compression', 'None', 'fps', 2 );
    end
    %PLEASE DONT USE THE CODE FOR COMMERCIAL PURPOSES!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    I have done something with parallel matlab conversion but i am not sure is completely correct. Any suggestions (for both parallel matlab and CUDA conversion)?
    ->You can also send me email.
  2. shyni
    Apr 10, 2013
    I want to implement LZW compression algm in CUDA.first simulate the algorithm in mathlab then convert to Cuda is a better approach?then please specify the steps of conversion.is there any chance for error ?please reply soon..I am stared to code directly on cuda emulator.
    Tankns and regars.
    shyni
