Hi Guys, this is my first post. I included a 2 led flip flop flasher circuit in one of my projects. In the beginning it used 5v as the power source. I would like to use 24v as the power supply. I changed the resistors in front of the LED from a 470R to a 2K2 so as not to blow the LED's. I thought that the 100K resistors were used as a throttle in the discharge of the caps, so I played around with the values there but when I put 24v on the input the frequency of the flash is very fast and does not change. I tried all the way up to 3M9. I would like to know if I should change the Cap value from a 10uf to a bigger one? and also how would I start to calculate the correct values in this circuit. I must state the original circuit was downloaded off the net and I just blindly followed it and it worked (with 5v). Looking forward to some help. Thanks
