The core problem is you don't know how to adjust the pot in your simulator, if you set the pot in the position for 0 amps then that is what you will get. If you set the pot for the other end (maximum current) then that is what you will get. Because this is a variable component you set it for what you want.
To prove my point try the following...
You will find the current is a shade over 30ma.
A question for Wookie, I had thought of the temperature variability in the diodes, would feeding them with a LM317 constant current source help? Before you jump on this Smilem, all electronics is suseptable to temperature variation, I'm just curious if it can be minimized.
