This is what I mean by a volume control. If the circuit stops completely, try more resistance in the control, like 50k ohms or 100k ohms.
The gate of the mosfet drops dead at 20 volts, and the performance curves tell me you need to allow at least 10 volts, so anywhere from 10V to 20V will work. Whatever you have in stock.OK IL try to get some resistors since it doesn't cost that much. So I should get a 10v zener or 16volt right?
