I read all of the posts. The 741 datasheet (TI version) clearly states that guaranteed input voltage range is 3V from either supply rail. That clearly means that when operated from a single supply, support for voltages less than 3V are not guaranteed.If you had read post #2 you would have seen that other members agree with me. 741 cannot read low voltages. <1v is a low voltage.
You were told to use appropriate power supplies or use a different opamp. That doesn't make LM741 a bad opamp; you just have to know it's limitations and how to deal with them.
