Help Tektronix 466 repair advice
Discussion in 'General Electronics Chat' started by epicfatigue, Mar 20, 2013.
  1. epicfatigue
    Feb 22, 2013
    27
    Hey everyone, i am getting into electronics and have been toying with them for the last 8 months.
    I have repaired 3 CRT arcade monitors thus far so by basic recapping and fault finding,
    However i am alittle stumped as to where to start with this.
    I brought it to learn how they work and gain some experience however i think it is broken i have taken a video of its symptoms if someone can point me in the right direction that would be fantastic, i pulled it apart to have a quick look and this thing has caps that are massive!
    The Manual is here.
    http://www.ko4bb.com/manuals/index.php?dir=Tektronix/Tektronix_-_465_Oscilloscope
    The one thing i want to know before i go diving into this is how i discharge it.
    I can not see an anode cap!
  2. Dodgydave
    Jun 22, 2012
    5,143
    768
    Looking at the power supply diagram on section 12, check that all supplies are there first, this is the best place to start looking, then see what happens when the beam finder button is pressed.
  3. spinnaker
    Oct 29, 2009
    5,065
    1,176
    Not that there aren't a lot of good folks around here but you should check out the Tektronix Yahoo group. Those guys eat, sleep and breath Tek.
  4. epicfatigue
    Feb 22, 2013
    27
    fantastic i have just joined there group, i shall test this tonight when i get home cant wait to get this thing working.
  5. epicfatigue
    Feb 22, 2013
    27
    Hey everyone,
    First off I LOVE TEST POINTS that made it so easy!
    So here are my results for test points
    Expected Result
    +65v +65.12v
    +15v +15.05v
    +5v +5v
    -8V +0.71v
    -15v -15.18v
    +140v +139.80v
    So it appears the -8V is where we start hunting!
  6. Sue_AF6LJ
    Member
    Mar 16, 2013
    45
    27
  7. spinnaker
    Oct 29, 2009
    5,065
    1,176
    That is good news.
    I had a similar issue one of my voltages dropped out. Can't remember which. Turns out it was a bad op amp in a very accessible place. I understand it is a common problem.
    I have a 475A power supply schematic. Not sure if it is the same. But I promised not to share it anyway since the person that sent it to me makes his living off of selling them.
    If the 475A is anything like the 466 you should check for 464A. If you find it you might just consider trying to swap it out. It is a common op amp that you will find at Radio Shack.
    There really is not that much to that circuit. One op amp and 3 transistors.
  8. spinnaker
    Oct 29, 2009
    5,065
    1,176
    Well did you get this. working?
  9. epicfatigue
    Feb 22, 2013
    27
    nope only just found the diagram for the power supply there is a few things in there will be checking them out over the next few days.
    mostly transistors. just need to look up how to test them correctly
  10. epicfatigue
    Feb 22, 2013
    27
    okay so i finally found the correct diagram,
    Layout is Page 275
    And Power Supply & distraction page 292
    I have highlighted all the components and i am going to remove them 1 by 1 and test them there is only a total of 17 components
    3 transistors
    5 capacitors
    7 resistors
    1 VR resistor
    1 op amp
    Was thinking about testing them in that order.
  11. spinnaker
    Oct 29, 2009
    5,065
    1,176
    Take a look at that opamp. It was what was wrong with mine and I understand a common point of failure. It's easy enough to swap out as it should be in a socket.
  12. epicfatigue
    Feb 22, 2013
    27
    yeah i did have a look at it, its not in a socket on mine,
    However is appears that the input voltage to generate the -8 is incorrect.
    Leads me to believe its a component further upstream.
  13. spinnaker
    Oct 29, 2009
    5,065
    1,176
    Do you have the 50V? You should if you have the other voltages. It could be on mine it was replaced before and whomever repaired it put a socket in.
    Do you have that 3.8V?
    I'd take all of the voltage measurements and post on the Tek yahoo group.
    I sure hope it is not the filter cap. Those babies are really buried. But they probably should be replaced anyway.
  14. epicfatigue
    Feb 22, 2013
    27
    Hey most of mine are in sockets, it could be whoever replaced this didnt put one in?
    Who knows ill put a socket in it anyways.
    yeah i am praying it is not c1771 that baby is massive, 5500uf
  15. spinnaker
    Oct 29, 2009
    5,065
    1,176
    Sadly that cap will need to be replaced soon anyway. It is probably long past due unless you are sure it has been refurbished in the last few years. It is not so bad that it is big but how it is buried and soldered in that pcb.
    This is a reason why I sold my 475A and bought a digital scope since I am mostly doing digital anyway. I have replaced some fairly large caps in the past but they have always been mounted on a chassis and in easy reach. I would not want to replace those one.
    Figures all but the suspect chip are on sockets. :(
  16. epicfatigue
    Feb 22, 2013
    27
    The caps are easy to replace for me take a few minutes the real issue is replacing the 8pin socket as that i have to dismantle the pcb to get to.
    No issue though my time is free and the chip is $00.50 however the large filter caps will be alot i assume
  17. epicfatigue
    Feb 22, 2013
    27
    She lives have not tested it but i have a trace line now!
    Bad transistor and op amp!
  18. spinnaker
    Oct 29, 2009
    5,065
    1,176
    Very cool. Now who told you it was the op amp? :)
    epicfatigue likes this.
  19. epicfatigue
    Feb 22, 2013
    27
    you and my circuit diagram!
    Hahah thanks for the heads up though, i did move it up on my list of things to test.
    Transistors then the opamp didnt bother about the others.
    I have a green line but i still do not know if it is working correctly,
    going to have to find a training manual or somthing that can teach me how to use them with some labs.
    Know of anything like this?
  20. epicfatigue
    Feb 22, 2013
    27
    well that was short lived was playing with it testing it, pressed the store button, now i have lost the trace again....
    checked the psu everything checks out...
    All the voltages are there guess something died further
    Any subjections ?
    https://www.youtube.com/watch?v=tXx0g8OF3QI
