Hi all,
I'm currently trying to repair an electronic motor controlled massage table which has stopped working.
Looking over the fairly basic control board, two diodes and the bridge rectifier have seemingly failed open.
Looking over the transformer, the primary winding isn't showing any continuity and there's a very low AC voltage detected on the secondary winding when powered. Presumably it's at least partly to blame for the problem.
I can find replacement diodes and the bridge rectifier easy enough, but I'm having trouble locating a replacement transformer. The code noted on the unit is HWX-66-36-01 which unfortunately doesn't reveal any replacement sources. The attached sticker states an input of 220V (50Hz) and an output of 24V, ultimately driving a 24V DC 3.5A motor. The transformer itself is fairly small (65 x 65 x 55mm).
There seems to be a massive plethora of transformers out there capable of meeting the 220V-24V part of the step down, however I'd be very grateful for some guidance narrowing the choices down a little in terms of the spec I'd need.
